HP Pavilion N3350 Fan Replacement
  1. HP Pavilion N3350 Fan Replacement, Fan: step 1, image 1 of 1
    • Locate the fan on the underside of the laptop.
  2. HP Pavilion N3350 Fan Replacement: step 2, image 1 of 1
    • Using a Phillips #1 screwdriver, remove the 4.5 mm screw securing the fan cover to the device.
  3. HP Pavilion N3350 Fan Replacement: step 3, image 1 of 1
    • Use a plastic spudger tool to free the cover.
    • The fan cover is extremely fragile and easy to break. Use caution during this step.
  4. HP Pavilion N3350 Fan Replacement: step 4, image 1 of 3 HP Pavilion N3350 Fan Replacement: step 4, image 2 of 3 HP Pavilion N3350 Fan Replacement: step 4, image 3 of 3
    • Lift the fan up from the device.
    • If you're cleaning the fan, stop at this step, and remove any build up. This can be done with tweezers and canned air.
    • Disconnect the fan cable to fully remove the fan from the device.
Emily Hatstat
481 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 101
