HP Pavilion G7-2289wm Optical Drive Replacement
  1. HP Pavilion G7-2289wm Optical Drive Replacement, Battery: step 1, image 1 of 1
    • Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
    • Lift the battery up, and pull towards the center of the laptop to remove it.
  2. HP Pavilion G7-2289wm Optical Drive Replacement, Optical Drive: step 2, image 1 of 1
    • Loosen the screw that secures the service cover using a Phillips #0 screwdriver.
    • Lift the edge of the service cover up and forward until it’s at an angle to remove it.
  3. HP Pavilion G7-2289wm Optical Drive Replacement: step 3, image 1 of 2 HP Pavilion G7-2289wm Optical Drive Replacement: step 3, image 2 of 2
    • Remove the screw that secures the optical drive to the laptop using a Phillips #0 screwdriver.
    • Slide the optical drive out of the laptop.
Ryson Smith
636 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 279
