HP Pavilion DV2160BR DVD±RW Drive Replacement
  1. HP Pavilion DV2160BR DVD±RW Drive Replacement, Battery: step 1, image 1 of 1
    • Start with the bottom of the laptop facing up.
  2. HP Pavilion DV2160BR DVD±RW Drive Replacement: step 2, image 1 of 2 HP Pavilion DV2160BR DVD±RW Drive Replacement: step 2, image 2 of 2
    • Locate the battery compartment at the rear of the device.
    • There is a slider button located under the left side of the battery compartment. It is indicated by a battery symbol. Move the slider to the left and lift the battery out.
  3. HP Pavilion DV2160BR DVD±RW Drive Replacement, DVD±RW Drive: step 3, image 1 of 1
    • Locate the locking screw which is located in a recessed hole on the underside of the laptop.
    • Remove the M2.5X3-Lg #1 Phillips screw.
  4. HP Pavilion DV2160BR DVD±RW Drive Replacement: step 4, image 1 of 2 HP Pavilion DV2160BR DVD±RW Drive Replacement: step 4, image 2 of 2
    • Locate the CD drive tray release hole on the front of the drive.
    • Straighten a paper clip and push it gently into the CD drive tray release hole.
    • The drive tray will pop open.
  5. HP Pavilion DV2160BR DVD±RW Drive Replacement: step 5, image 1 of 1
    • Grasp the side edges of the drive tray.
    • Gently pull the drive from the laptop.
  6. HP Pavilion DV2160BR DVD±RW Drive Replacement: step 6, image 1 of 1
    • Locate the mounting bracket which is attached to the back of the drive.
    • Remove the two M2x3-Lg #0 Phillips screws.
Brandon MacDonald
239 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 229
