HP Pavilion DV1000 Screen Replacement
  1. HP Pavilion DV1000 Screen Replacement, Battery: step 1, image 1 of 1
    • Shut down the computer.
    • Disconnect all external devices and cables from the computer.
  2. HP Pavilion DV1000 Screen Replacement: step 2, image 1 of 1
    • Flip the laptop over.
  3. HP Pavilion DV1000 Screen Replacement: step 3, image 1 of 2 HP Pavilion DV1000 Screen Replacement: step 3, image 2 of 2
    • Locate the gray sliding tab next to the black bar where the battery is located.
    • Slide the gray sliding tab to the left until you hear a distinct click.
    • The inside edge of the battery should pop up.
  4. HP Pavilion DV1000 Screen Replacement: step 4, image 1 of 3 HP Pavilion DV1000 Screen Replacement: step 4, image 2 of 3 HP Pavilion DV1000 Screen Replacement: step 4, image 3 of 3
    • Grasp the inside edge of the battery.
    • Lift the inside edge of the battery up to detach the battery from the laptop.
  5. HP Pavilion DV1000 Screen Replacement, Keyboard: step 5, image 1 of 1
    • Remove the highlighted screws.
    • After removing the screws, flip the laptop over.
  6. HP Pavilion DV1000 Screen Replacement: step 6, image 1 of 2 HP Pavilion DV1000 Screen Replacement: step 6, image 2 of 2
    • Open the laptop.
    • Use the spudger to lift the keyboard.
    • Do not pull the keyboard up and away from the computer, because it is still attached by a ribbon cable.
    • Press the two white clips forward with your fingers and gently pull the ribbon from the clips.
  7. HP Pavilion DV1000 Screen Replacement, Media Keys: step 7, image 1 of 1
    • Turn the laptop upside-down again.
  8. HP Pavilion DV1000 Screen Replacement: step 8, image 1 of 2 HP Pavilion DV1000 Screen Replacement: step 8, image 2 of 2
    • Turn the laptop right-side up. Open the screen and tilt it all the way back.
    • Locate the media keys.
    • Gently lift up the media key strip using the plastic pry tool.
    • If there is too much resistance when prying, stop and search for cause of the resistance. Do not force the media keys.
  9. HP Pavilion DV1000 Screen Replacement, Screen: step 9, image 1 of 1
    • Remove the rubber inserts with the spudger.
    • Note: When reassembling, notice that the two lower rubber pieces are flatter than the four rubber pieces located at the top of the screen.
    • Remove the screws behind the rubber inserts.
  10. HP Pavilion DV1000 Screen Replacement: step 10, image 1 of 2 HP Pavilion DV1000 Screen Replacement: step 10, image 2 of 2
    • Carefully pry loose the screen casing with a plastic prying tool.
  11. HP Pavilion DV1000 Screen Replacement: step 11, image 1 of 2 HP Pavilion DV1000 Screen Replacement: step 11, image 2 of 2
    • Remove the plug by prying it loose with the spudger.
    • Pulling the plug with your fingers could be potentially dangerous unless you are wearing work gloves.
  12. HP Pavilion DV1000 Screen Replacement: step 12, image 1 of 1
    • Remove the single screw marked in the image.
    • Be careful not to break the clips or pull any wires.
  13. HP Pavilion DV1000 Screen Replacement: step 13, image 1 of 3 HP Pavilion DV1000 Screen Replacement: step 13, image 2 of 3 HP Pavilion DV1000 Screen Replacement: step 13, image 3 of 3
    • Remove the 4 screws marked in the picture using the #00 Phillips head screwdriver.
    • Support the back cover and set it down on the desk. Do not pull off the back cover.
  14. HP Pavilion DV1000 Screen Replacement: step 14, image 1 of 2 HP Pavilion DV1000 Screen Replacement: step 14, image 2 of 2
    • Remove the screws on each side of the screen. There are four screws on each side.
    • Remove the screen.
Tyler Latour
266 Reputation
3 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 3,394
