Introduction
The hard drive may malfunction if physically damaged or put under a lot of stress. Use this guide to replace it if the computer won't boot and or is displaying errors.
Remove the following six screws with a Phillips #1 screwdriver:
Two 7 mm screws.
Two 7 mm screws.
Two 4.8 mm screws.
At step 11 there are only two screws. Those marked in yellow in the picture.
Step 10, the screws under the end caps. My device also only had the yellow screws in place.
Lift the black retaining bar that holds down the two hard drive ribbons to unlock them.
8 other people completed this guide.
One Comment
Thank you. Couldn’t figure out why those end caps wouldn’t budge. Dang hidden screws! Kudos!
