HP Pavilion 17-e146us Keyboard Replacement
    1. HP Pavilion 17-e146us Keyboard Replacement, Battery: step 1, image 1 of 1
      • Turn the device over.
      Ask FixBot
    2. HP Pavilion 17-e146us Keyboard Replacement: step 2, image 1 of 2 HP Pavilion 17-e146us Keyboard Replacement: step 2, image 2 of 2
      • Move the battery lock switch to the right to unlock. The battery release button will unlock the battery from the computer.
      • The battery release button is located above the the battery.
      Ask FixBot
    3. HP Pavilion 17-e146us Keyboard Replacement: step 3, image 1 of 1
      • The battery will unlock from the computer.
      • Remove the unlocked battery from the computer.
      Ask FixBot
    1. HP Pavilion 17-e146us Keyboard Replacement, Keyboard: step 4, image 1 of 3 HP Pavilion 17-e146us Keyboard Replacement, Keyboard: step 4, image 2 of 3 HP Pavilion 17-e146us Keyboard Replacement, Keyboard: step 4, image 3 of 3
      • Remove the 6.25 mm screw in the left-lower hand corner of the battery port using a Phillips head screw driver.
      Ask FixBot
    2. HP Pavilion 17-e146us Keyboard Replacement: step 5, image 1 of 1
      • Remove the HP protect smart ventilation case.
      • The smart ventilation is a part of the back cover of the device
      Ask FixBot
    3. HP Pavilion 17-e146us Keyboard Replacement: step 6, image 1 of 1
      • Remove seven 6.5 mm screws using a Phillips #0 screwdriver.
      • Remove four 3.0 mm screws located in the charger port using a Phillips #0 screwdriver.
      Ask FixBot
    4. HP Pavilion 17-e146us Keyboard Replacement: step 7, image 1 of 2 HP Pavilion 17-e146us Keyboard Replacement: step 7, image 2 of 2
      • Pull and remove the disk drive.
      • The disk drive is located on the left side of the device when it is turned over.
      • Remove two 3.00 mm screws on the inside of the disk drive using a Phillips screwdriver.
      Ask FixBot
    5. HP Pavilion 17-e146us Keyboard Replacement: step 8, image 1 of 1
      Tool used on this step:
      Buy
      • Apply firm pressure inside the release port using a narrow tool such as a screw driver or tweezers.
      • The release port releases the keyboard.
      Ask FixBot
    6. HP Pavilion 17-e146us Keyboard Replacement: step 9, image 1 of 1
      • Flip device over so that the cover is facing towards you
      Ask FixBot
    7. HP Pavilion 17-e146us Keyboard Replacement: step 10, image 1 of 3 HP Pavilion 17-e146us Keyboard Replacement: step 10, image 2 of 3 HP Pavilion 17-e146us Keyboard Replacement: step 10, image 3 of 3
      • Open device. The keyboard should be separate from the inside panel.
      • If the keyboard does not automatically pop out, use a spudger or opening tool along the edge of the front panel and the keyboard to pop the keyboard out.
      • Detach the keyboard's cable connector from the motherboard.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 55
All Time: 1,444
