HP Pavilion 15-p214dx Disk Drive Replacement
  1. HP Pavilion 15-p214dx Disk Drive Replacement, Disk Drive: step 1, image 1 of 3 HP Pavilion 15-p214dx Disk Drive Replacement, Disk Drive: step 1, image 2 of 3 HP Pavilion 15-p214dx Disk Drive Replacement, Disk Drive: step 1, image 3 of 3
    • Place your laptop on a flat surface with the bottom facing upwards. The HP logo should be facing downwards.
    • Locate the disk drive screw. It is a 7mm screw that can be found to the upper left on label on the bottom of the computer and is marked with a disk drive symbol.
    • Remove this screw using a Philips #0 screwdriver.
  2. HP Pavilion 15-p214dx Disk Drive Replacement: step 2, image 1 of 2 HP Pavilion 15-p214dx Disk Drive Replacement: step 2, image 2 of 2
    • Place your thumbnail between the disk drive exterior and your laptop's bottom cover.
    • If your nail is not long enough to do this, you can use a prying tool instead.
    • Pull outwards to slide the disk drive out of its slot.
    • Due to how the disk drive's slot is constructed, the drive must be properly aligned to fit back in. It may take a couple attempts to properly align it.
Patrick Seaver
1,001 Reputation
8 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 244
