Introduction
This guide will show you how to remove your HP Pavilion 15-p214dx’s battery if you need to remove or replace it. The only tools you need to complete this guide are your hands, so completing this task is fairly easy and straightforward.
Place your laptop on a flat surface with the bottom facing upwards. The HP logo should be facing downwards.
Slide the battery lock (the switch at the upper left corner of the laptop's underside) to the right until it clicks into place.
Slide the battery release latch (the upper right-hand switch on the laptop's bottom) to the left.
While holding the latch in place, remove the battery from the laptop's battery bay.
