HP Pavilion 15-e043cl Optical Drive Replacement
    1. HP Pavilion 15-e043cl Optical Drive Replacement, Battery: step 1, image 1 of 2 HP Pavilion 15-e043cl Optical Drive Replacement, Battery: step 1, image 2 of 2
      • Flip the device over.
      • Slide the battery switch on the right half of the laptop.
      • Make sure the device is powered off, and that it is not connected to any power sources.
      Ask FixBot
    2. HP Pavilion 15-e043cl Optical Drive Replacement: step 2, image 1 of 2 HP Pavilion 15-e043cl Optical Drive Replacement: step 2, image 2 of 2
      • Lift the battery up and out of the device by the inward-facing edge.
      Ask FixBot
    1. HP Pavilion 15-e043cl Optical Drive Replacement, Maintenance Panel: step 3, image 1 of 3 HP Pavilion 15-e043cl Optical Drive Replacement, Maintenance Panel: step 3, image 2 of 3 HP Pavilion 15-e043cl Optical Drive Replacement, Maintenance Panel: step 3, image 3 of 3
      • Unscrew the single Phillips #0 captive screw that was previously hidden by the battery.
      • The screw can not, and should not, be fully removed.
      • Slide the maintenance panel away from the battery compartment to release it.
      Ask FixBot
    1. HP Pavilion 15-e043cl Optical Drive Replacement, Optical Drive: step 4, image 1 of 2 HP Pavilion 15-e043cl Optical Drive Replacement, Optical Drive: step 4, image 2 of 2
      • Remove the black screw nearby to the disk tray.
      • Push the disk tray out of the laptop near the stamp that says "RELEASE."
      Ask FixBot
Cace Letendre
528 Reputation
6 Guides authored
UMass Dartmouth, Team 4-5, Sinclaire Fall 2022 Member of UMass Dartmouth, Team 4-5, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G5
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 51
All Time: 461
