HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement
    1. HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Flip it over: step 1, image 1 of 1
      • First thing you'll do is flip it over, remove any SD cards, USBs, and remove any case.
      Ask FixBot
    2. HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Remove screws: step 2, image 1 of 3 HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Remove screws: step 2, image 2 of 3 HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Remove screws: step 2, image 3 of 3
      • There will be about 6 screws you'll need to remove.
      • You will have to at least partially remove the rubber feet to access 3 of the screws.
      • The screws are really tiny, so I recommend putting them in a Tupperware or Ziploc if you don't have a magnetic screw tray.
      Ask FixBot
    3. HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Credit Card or Pry Tool: step 3, image 1 of 2 HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Credit Card or Pry Tool: step 3, image 2 of 2
      • You'll use a credit card, ID card, or pry tool to separate the bottom of the laptop from the rest of it. Make sure it's plastic, not metal.
      • You might want to use multiple to hold sections open as you work your way around.
      Ask FixBot
    4. HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Pop That Sucker Off: step 4, image 1 of 1
      • You remove the bottom to reveal the guts.
      Ask FixBot
    5. HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Where's Waldo?: step 5, image 1 of 2 HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Where's Waldo?: step 5, image 2 of 2
      • Find the WiFi module.
      Ask FixBot
    6. HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Unplugging: step 6, image 1 of 1
      • Detach the antenna cables.
      Ask FixBot
    7. HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Unscrew the Module: step 7, image 1 of 2 HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Unscrew the Module: step 7, image 2 of 2
      • Unscrew the screw.
      • It will pop up once it's unscrewed. That's normal.
      Ask FixBot
    8. HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Yoink: step 8, image 1 of 2 HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Yoink: step 8, image 2 of 2
      • Pull the module out.
      Ask FixBot
    9. HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Put in the New Module: step 9, image 1 of 1
      • Put in the new module.
      • You might need to push the end to get it to seat.
      Ask FixBot
    10. HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Screw it in: step 10, image 1 of 2 HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Screw it in: step 10, image 2 of 2
      • Push it flat and screw it in.
      Ask FixBot
    11. HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Reattach Cables: step 11, image 1 of 3 HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Reattach Cables: step 11, image 2 of 3 HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Reattach Cables: step 11, image 3 of 3
      • Reattach the antenna cables.
      • They should have labels "1" and "2" on the cables. Attach them to the points labeled "1" and "2" on your new WiFi module.
      • They're teeny-tiny snap buttons, like miniature versions of what you'd find on a jacket.
      • Make sure they snap on properly, you might need to use your thumbnail. You can give them a gentle tug to make sure they're actually attached.
      Ask FixBot
    12. HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Close it up!: step 12, image 1 of 1
      • Snap the lid back on
      • Put the lid screws back in
      • Stick the sticky rubber feetsies back on
      • Plug back in any SD cards, USBs, and put your case back on if you have one
      Ask FixBot
    13. HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Drivers (Software): step 13, image 1 of 1
      • Go to this link and install the WiFi and Bluetooth drivers that Intel recommends.
      Ask FixBot
      • Power cycle your laptop (off and on again).
      • That's it, you're good to go!
      Ask FixBot
You're all set!
Quinn Enestvedt
568 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 49
All Time: 197
