Introduction
Want to add a way faster storage option than the HDD the laptop comes with? You're in luck- it's super easy!
First thing you'll do is flip it over, remove any SD cards, USBs, and remove your case if you have one.
There will be about 6 screws you'll need to remove.
You will have to at least partially remove the rubber feet to access 3 of the screws.
The screws are really tiny, so I recommend putting them in a Tupperware or Ziploc if you don't have a magnetic screw tray.
You'll use a credit card, ID card, or pry tool to separate the bottom of the laptop from the rest of it. Make sure it's plastic, not metal.
You might want to use multiple to hold sections open as you work your way around.
Snap the lid back on
Put the lid screws back in
Stick the sticky rubber feetsies back on
Plug back in any SD cards, USBs, and put your case back on if you have one
If you want to make your NVME your new boot drive, you'll need a different, more difficult guide. Otherwise, you're set!
