HP Pavilion 15-cd040wm CD Drive Replacement
  1. HP Pavilion 15-cd040wm CD Drive Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: step 1, image 1 of 2 HP Pavilion 15-cd040wm CD Drive Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: step 1, image 2 of 2
    • The first step is to remove the four rubber non-slip pads on the bottom of the laptop to expose screws hidden underneath them. Peel off each tab with your fingers.
    • If you have trouble gripping a tab, use a spudger to wedge it loose.
  2. HP Pavilion 15-cd040wm CD Drive Replacement: step 2, image 1 of 2 HP Pavilion 15-cd040wm CD Drive Replacement: step 2, image 2 of 2
    • 3x 10mm Phillips scews
    • 2x 5mm Phillips screws
    • 6x 6mm Phillips screws
    • Remove all screws using a size Phillips #0 screwdriver.
  3. HP Pavilion 15-cd040wm CD Drive Replacement: step 3, image 1 of 3 HP Pavilion 15-cd040wm CD Drive Replacement: step 3, image 2 of 3 HP Pavilion 15-cd040wm CD Drive Replacement: step 3, image 3 of 3
    • Using the iFixit opening tool, carefully pry along the sides of the back cover.
    • After all of the edges of the back cover have been freed, use your opening tool to carefully unclip the tabs holding the back cover to the CD drive.
    • After everything is unclipped, you can safely remove the back cover from the rest of the device.
  4. HP Pavilion 15-cd040wm CD Drive Replacement, Battery: step 4, image 1 of 2 HP Pavilion 15-cd040wm CD Drive Replacement, Battery: step 4, image 2 of 2
    • 2x 5mm Philips screws
    • 2x 3mm Philips screws
  5. HP Pavilion 15-cd040wm CD Drive Replacement: step 5, image 1 of 2 HP Pavilion 15-cd040wm CD Drive Replacement: step 5, image 2 of 2
    • Gently pull up on the battery and tilt it away from the rest of the laptop chassis.
    • Pull out the battery at an angle and lift it out of the laptop.
  6. HP Pavilion 15-cd040wm CD Drive Replacement, CD Drive: step 6, image 1 of 2 HP Pavilion 15-cd040wm CD Drive Replacement, CD Drive: step 6, image 2 of 2
    • Slide the CD drive out the side of the laptop.
Brian Cornet
316 Reputation
3 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 487
