Introduction
If your battery fails to charge or doesn't hold a charge long enough to be productive anymore, you most likely have a faulty battery that requires replacement.
To access the battery, you will first need to open your HP Pavilion 15-cd040wm by disassembling its back cover.
Before beginning, make sure to power off your laptop completely and disconnect it from any external power source.
The first step is to remove the four rubber non-slip pads on the bottom of the laptop to expose screws hidden underneath them. Peel off each tab with your fingers.
3x 10mm Phillips scews
2x 5mm Phillips screws
6x 6mm Phillips screws
Remove all screws using a size Phillips #0 screwdriver.
Using the iFixit opening tool, carefully pry along the sides of the back cover.
After all of the edges of the back cover have been freed, use your opening tool to carefully unclip the tabs holding the back cover to the CD drive.
After everything is unclipped, you can safely remove the back cover from the rest of the device.
2x 5mm Philips screws
2x 3mm Philips screws
Gently pull up on the battery and tilt it away from the rest of the laptop chassis.
Pull out the battery at an angle and lift it out of the laptop.
