HP Pavilion 15-cd040wm Back Cover Disassembly
  1. HP Pavilion 15-cd040wm Back Cover Disassembly, HP Pavilion 15-cd040wm Back Cover Disassembly: step 1, image 1 of 2 HP Pavilion 15-cd040wm Back Cover Disassembly, HP Pavilion 15-cd040wm Back Cover Disassembly: step 1, image 2 of 2
    • The first step is to remove the four rubber non-slip pads on the bottom of the laptop to expose screws hidden underneath them. Peel off each tab with your fingers.
    • If you have trouble gripping a tab, use a spudger to wedge it loose.
  2. HP Pavilion 15-cd040wm Back Cover Disassembly: step 2, image 1 of 2 HP Pavilion 15-cd040wm Back Cover Disassembly: step 2, image 2 of 2
    • 3x 10mm Phillips scews
    • 2x 5mm Phillips screws
    • 6x 6mm Phillips screws
    • Remove all screws using a size Phillips #0 screwdriver.
  3. HP Pavilion 15-cd040wm Back Cover Disassembly: step 3, image 1 of 3 HP Pavilion 15-cd040wm Back Cover Disassembly: step 3, image 2 of 3 HP Pavilion 15-cd040wm Back Cover Disassembly: step 3, image 3 of 3
    • Using the iFixit opening tool, carefully pry along the sides of the back cover.
    • After all of the edges of the back cover have been freed, use your opening tool to carefully unclip the tabs holding the back cover to the CD drive.
    • After everything is unclipped, you can safely remove the back cover from the rest of the device.
    You did not describe how to remove the CD drive. It suddenly disappeared between step 2 and step 3.
    Stan - Reply
3 other people completed this guide.
Joe Krawczyk
397 Reputation
2 Guides authored
3 Comments
It's not listed in here, but to remove the cd tray, just pull it straight out. The whole drive has a connector at the back.
Gage Cook - Reply
I’m trying to remove my backing and it seems to have a lip that goes over the edge, so I’m having a hard time getting it apart. Any suggestions?
Laura Green - Reply
Is this the same process for the HP Pavilion 15-cc055od? Do I pull out the disk drive as well? How would I remove the hard drive?
Baconface Smith - Reply
Past 24 Hours: 7
Past 7 Days: 39
Past 30 Days: 148
All Time: 8,270
