HP Pavilion 15-bk020wm Battery Replacement
  1. HP Pavilion 15-bk020wm Battery Replacement, Keyboard Cover: step 1, image 1 of 2 HP Pavilion 15-bk020wm Battery Replacement, Keyboard Cover: step 1, image 2 of 2
    • Before you begin, turn the laptop off and unplug it from the power source.
    • Remove the 4 computer feet. (Our device didn't have these; they can be taken off with a plastic spudger.)
    • Remove the two screw cover strips.
    • Remove the two screw cover plugs.
    • Unscrew all 12 screws (size: Phillips M2.5×7.0 ) from the bottom of the computer.
  2. HP Pavilion 15-bk020wm Battery Replacement: step 2, image 1 of 3 HP Pavilion 15-bk020wm Battery Replacement: step 2, image 2 of 3 HP Pavilion 15-bk020wm Battery Replacement: step 2, image 3 of 3
    • Turn the computer over to the front.
    • Open the laptop.
    • Use a plastic pry tool to pry up the keyboard cover near the hinge on both the right and left side, and work your way towards the touchpad.
  3. HP Pavilion 15-bk020wm Battery Replacement: step 3, image 1 of 1
    • Tilt the keyboard cover up slightly.
    • Do not fully remove the keyboard, as it is still attached to the laptop by some cables.
  4. HP Pavilion 15-bk020wm Battery Replacement, Battery: step 4, image 1 of 2 HP Pavilion 15-bk020wm Battery Replacement, Battery: step 4, image 2 of 2
    • Detach the blue ZIF cable from the bottom of the laptop.
    • Use a plastic opening tool to flip up the two ZIF cables connecting the battery to the motherboard.
  5. HP Pavilion 15-bk020wm Battery Replacement: step 5, image 1 of 1
    • Remove the four Phillips M2.5x4.4 screws using the Phillips 00 located along the perimeter of the battery.
  6. HP Pavilion 15-bk020wm Battery Replacement: step 6, image 1 of 1
    • Lift the damaged battery from the laptop.
    • Insert the new battery.
Past 24 Hours: 11
Past 7 Days: 60
Past 30 Days: 306
All Time: 68,793
