HP Pavilion 15-b109wm Keyboard Replacement
  1. HP Pavilion 15-b109wm Keyboard Replacement, Battery: step 1, image 1 of 1
    • Power off the device and disconnect from any power source.
  2. HP Pavilion 15-b109wm Keyboard Replacement: step 2, image 1 of 1
    • Turn the device upside down and ensure the back of the device is facing you.
  3. HP Pavilion 15-b109wm Keyboard Replacement: step 3, image 1 of 3 HP Pavilion 15-b109wm Keyboard Replacement: step 3, image 2 of 3 HP Pavilion 15-b109wm Keyboard Replacement: step 3, image 3 of 3
    • Push both buttons towards one another simultaneously. The battery slightly pops out.
  4. HP Pavilion 15-b109wm Keyboard Replacement: step 4, image 1 of 3 HP Pavilion 15-b109wm Keyboard Replacement: step 4, image 2 of 3 HP Pavilion 15-b109wm Keyboard Replacement: step 4, image 3 of 3
    • Pull out the battery from the device's battery slot.
  5. HP Pavilion 15-b109wm Keyboard Replacement, Keyboard: step 5, image 1 of 2 HP Pavilion 15-b109wm Keyboard Replacement, Keyboard: step 5, image 2 of 2
    • Use JIS #1 screwdriver to remove the eleven 6 mm screws.
  6. HP Pavilion 15-b109wm Keyboard Replacement: step 6, image 1 of 1
    • Locate the two screw holes that allow access to removing the keyboard.
    • There is a keyboard sign beside both keyboard access holes.
  7. HP Pavilion 15-b109wm Keyboard Replacement: step 7, image 1 of 1
    Tool used on this step:
    Heavy-Duty Spudger
    Buy
    • Turn the device onto its side.
    • Using a heavy duty spudger, gently disengage the keyboard.
  8. HP Pavilion 15-b109wm Keyboard Replacement: step 8, image 1 of 2 HP Pavilion 15-b109wm Keyboard Replacement: step 8, image 2 of 2
    • Using a plastic opening tool, release the keyboard clips.
  9. HP Pavilion 15-b109wm Keyboard Replacement: step 9, image 1 of 1
    • Tilt the keyboard to expose the Zero Insertion Force connector to which the keyboard cable is attached.
  10. HP Pavilion 15-b109wm Keyboard Replacement: step 10, image 1 of 3 HP Pavilion 15-b109wm Keyboard Replacement: step 10, image 2 of 3 HP Pavilion 15-b109wm Keyboard Replacement: step 10, image 3 of 3
    • Disconnect the keyboard cable from the motherboard by detaching the Zero Insertion Force connector.
    • To detach the connector, release by lifting the black plastic tab up.
David Atunlute
241 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 749
