HP Pavilion 15-au123cl Hard Drive Replacement
  1. HP Pavilion 15-au123cl Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl Hard Drive Replacement: step 2, image 1 of 2 HP Pavilion 15-au123cl Hard Drive Replacement: step 2, image 2 of 2
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  3. HP Pavilion 15-au123cl Hard Drive Replacement: step 3, image 1 of 2 HP Pavilion 15-au123cl Hard Drive Replacement: step 3, image 2 of 2
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
  4. HP Pavilion 15-au123cl Hard Drive Replacement: step 4, image 1 of 2 HP Pavilion 15-au123cl Hard Drive Replacement: step 4, image 2 of 2
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  5. HP Pavilion 15-au123cl Hard Drive Replacement: step 5, image 1 of 3 HP Pavilion 15-au123cl Hard Drive Replacement: step 5, image 2 of 3 HP Pavilion 15-au123cl Hard Drive Replacement: step 5, image 3 of 3
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl Hard Drive Replacement, Hard Drive: step 6, image 1 of 3 HP Pavilion 15-au123cl Hard Drive Replacement, Hard Drive: step 6, image 2 of 3 HP Pavilion 15-au123cl Hard Drive Replacement, Hard Drive: step 6, image 3 of 3
    • The hard drive is located at the lower left area of the motherboard.
    • Using the spudger, lift the white latch holding the hard drive cable in place.
  7. HP Pavilion 15-au123cl Hard Drive Replacement: step 7, image 1 of 1
    • Using the opening tool, lift the hard drive out of the motherboard.
  8. HP Pavilion 15-au123cl Hard Drive Replacement: step 8, image 1 of 2 HP Pavilion 15-au123cl Hard Drive Replacement: step 8, image 2 of 2
    • Remove the hard drive cable from the hard drive.
  9. HP Pavilion 15-au123cl Hard Drive Replacement: step 9, image 1 of 2 HP Pavilion 15-au123cl Hard Drive Replacement: step 9, image 2 of 2
    • Pull off the plastic wedges on both sides of the hard drive.
10 other people completed this guide.
Mohammad Gardezi
1,420 Reputation
6 Guides authored
USF Tampa, Team S13-G3, Cagle Fall 2017 Member of USF Tampa, Team S13-G3, Cagle Fall 2017
USFT-CAGLE-F17S13G3
2 Members
6 Guides authored
1 Guide Comment
The latch on mine was black, and the socket on the m/b was white. Guess who ruined his m/b following these instructions?
TJ Fitzgerald - Reply
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 38
All Time: 7,325
