Introduction
The motherboard should be replaced if the laptop will not turn on with the charger plugged in. To avoid damaging electronic components, use a static discharge wrist strap. The only skill needed to complete this project is knowing how to use a screwdriver. With twenty minutes and a new motherboard, you can repair your computer for a fraction of the cost of replacing it.
Slide the battery lock latch on the left to unlock. Slide from left to right to unlock.
Flip computer over so that the bottom is facing the ceiling and the hinges are farthest from you.
Using the Phillips #1 screwdriver, remove the two 12mm screws located on the hinge covers.
Disconnect the wiring harness that is routed through the speaker from the motherboard.
Remove the wiring harness from the groove in the speaker.
Use the #000 screwdriver to remove the four 6mm screws attaching the motherboard to the laptop case.
