HP Pavilion 15-p Optical drive Replacement
  1. HP Pavilion 15-p Optical drive Replacement, Prepare the laptop: step 1, image 1 of 3 HP Pavilion 15-p Optical drive Replacement, Prepare the laptop: step 1, image 2 of 3 HP Pavilion 15-p Optical drive Replacement, Prepare the laptop: step 1, image 3 of 3
    • Shut the laptop down until it is hibernated or shut off. Do not remove power until both lights turn off.
  2. HP Pavilion 15-p Optical drive Replacement, Unlock the  battery: step 2, image 1 of 3 HP Pavilion 15-p Optical drive Replacement, Unlock the  battery: step 2, image 2 of 3 HP Pavilion 15-p Optical drive Replacement, Unlock the  battery: step 2, image 3 of 3
    • Once the computer is off, remove the battery. Switch the locking tab to the unlocked position.
  3. HP Pavilion 15-p Optical drive Replacement, Remove the battery: step 3, image 1 of 2 HP Pavilion 15-p Optical drive Replacement, Remove the battery: step 3, image 2 of 2
    • Remove the battery. Pull the battery forward and remove it from the laptop.
  4. HP Pavilion 15-p Optical drive Replacement, Remove the screw: step 4, image 1 of 3 HP Pavilion 15-p Optical drive Replacement, Remove the screw: step 4, image 2 of 3 HP Pavilion 15-p Optical drive Replacement, Remove the screw: step 4, image 3 of 3
    • Remove the screw that holds the optical drive in. To do this, use a Phillips #0 screwdriver. Slide the optical drive out once this screw is removed.
  5. HP Pavilion 15-p Optical drive Replacement, Remove the optical drive tab: step 5, image 1 of 2 HP Pavilion 15-p Optical drive Replacement, Remove the optical drive tab: step 5, image 2 of 2
    • Remove the screws holding the optical drive bracket onto the drive. To do this, use a Phillips #0 screwdriver.
  6. HP Pavilion 15-p Optical drive Replacement, Faceplate removal: step 6, image 1 of 3 HP Pavilion 15-p Optical drive Replacement, Faceplate removal: step 6, image 2 of 3 HP Pavilion 15-p Optical drive Replacement, Faceplate removal: step 6, image 3 of 3
    • Be careful not to break any clips. The faceplate will still be usable, but will be loose fitting.
    • To remove the faceplate, open the optical drive with a paper clip. Once the tray is released, use a flat tool to release the visible clip on the faceplate. Once done, the faceplate should come off.
3 other people completed this guide.
Nick
88,911 Reputation
49 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,540 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 64
All Time: 7,223
