Introduction
Unplug your device from any power source and turn off your laptop before beginning.
Use the spudger to pry off the two rubber feet near the hinge of the laptop. This will reveal two hidden 9mm screws.
You must remove eleven screws.
Four 9mm screws with the PH0 screwdriver.
Seven 6mm screws with the PH0 screwdriver.
Use the spudger to pry the corners of the laptop near the display hinges.
Pry around the seam of the laptop with the plastic opening tool until the backing begins to pull apart.
Use the plastic opening tool to lift the white tab up at the connection.
Pull the cable outwards.
Remove the battery cable from the motherboard by gently pulling out on the black part of the cable closest to the white tab.
Disconnect the black cable that attaches the speakers to the motherboard by gently pulling the cable outward.
Now you can fully remove the speakers.
