Fix Your Stuff
Right to Repair
Parts & Tools
You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
Using a spudger and a 00 Phillips head screwdriver, this guide will show how to remove a battery from an HP Omni 10 tablet in roughly 5 to 10 minutes. Be careful with the battery, as it can be volatile when punctured with metal instruments.
  1. Remove the back cover from the tablet.
    • Remove the back cover from the tablet.
    • The cover is securely fastened to the device and may be difficult to remove.
  2. Push the black plastic security flaps into an upward position.
    • Push the black plastic security flaps into an upward position.
    • Lift the small tab on the security strips up and peel them across the battery. They will be attached via adhesive.
    • Lift the tab on the strip up and pull it across the battery.
    • The orange strip does not fully detach from the tablet like the other three. It will only detach from one side.
  3. Unscrew the ten 3.3 mm screws securing the battery using a  00 Phillip's head screwdriver.
    • Unscrew the ten 3.3 mm screws securing the battery using a 00 Phillip's head screwdriver.
  4. Unhook the cord from the edge of the battery. Pull the wire circuit out and down.
    • Unhook the cord from the edge of the battery.
    • Pull the wire circuit out and down.
  5. Lift the battery up by its edges and remove it carefully. There will be adhesive holding the battery down. Lift the battery up by its edges and remove it carefully. There will be adhesive holding the battery down.
    • Lift the battery up by its edges and remove it carefully. There will be adhesive holding the battery down.
Alex Miller
228 Reputation
5 Guides authored
USF Tampa, Team 1-1, Leahy Fall 2016 Member of USF Tampa, Team 1-1, Leahy Fall 2016
USFT-LEAHY-F16S1G1
3 Members
10 Guides authored
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 39
All Time: 2,189
