HP Mini 311 Hard Drive Replacement
  1. HP Mini 311 Hard Drive Replacement, Battery: step 1, image 1 of 3 HP Mini 311 Hard Drive Replacement, Battery: step 1, image 2 of 3 HP Mini 311 Hard Drive Replacement, Battery: step 1, image 3 of 3
    • Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
  2. HP Mini 311 Hard Drive Replacement: step 2, image 1 of 2 HP Mini 311 Hard Drive Replacement: step 2, image 2 of 2
    • Slide the battery away from the device to remove.
  3. HP Mini 311 Hard Drive Replacement, Memory Shield: step 3, image 1 of 1
    • With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
    • The screws will remain in the shied.
  4. HP Mini 311 Hard Drive Replacement: step 4, image 1 of 2 HP Mini 311 Hard Drive Replacement: step 4, image 2 of 2
    • Lift the memory shield up and remove from the laptop.
  5. HP Mini 311 Hard Drive Replacement, Hard Drive: step 5, image 1 of 3 HP Mini 311 Hard Drive Replacement, Hard Drive: step 5, image 2 of 3 HP Mini 311 Hard Drive Replacement, Hard Drive: step 5, image 3 of 3
    • Grab the left black, plastic tab and carefully pull upward.
    • Be sure to pull carefully. Pulling too forcefully may damage the tab.
  6. HP Mini 311 Hard Drive Replacement: step 6, image 1 of 3 HP Mini 311 Hard Drive Replacement: step 6, image 2 of 3 HP Mini 311 Hard Drive Replacement: step 6, image 3 of 3
    • Grab a hold of the wire connecting the hard drive and the device.
    • Pull upward, perpendicular to the surface of the laptop, releasing the connector tethering the hard drive to the motherboard.
4 other people completed this guide.
Christian Santoyo
495 Reputation
6 Guides authored
Cal Poly, Team 20-4, Maness Winter 2013 Member of Cal Poly, Team 20-4, Maness Winter 2013
CPSU-MANESS-W13S20G4
4 Members
6 Guides authored
One Comment
What size hard drive does this unit take?
Travis Duncan - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 21
All Time: 4,345
