Introduction
Replacing the WWAN (Wireless Wide Area Network) card is easy and straightforward.
Hold the netbook top-side down with the lid closed.
Slide the plastic battery release latches towards the lock symbols.
Turn the netbook to view its edge.
Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
Use a plastic opening tool to disconnect the two gold antenna cables from the WWAN card.
Use a phillips #00 screwdriver to remove the 2 phillips 2.0 and 3.0 mm screws that secure the WWAN to the system board.
