HP Mini 110-3131dx Screen Replacement
    • Power off the laptop before trying to remove the battery.
    • Turn the laptop upside down, and locate the sliding tabs on the battery.
    • Slide both tabs in an inward direction, then slide the battery away from the laptop.
  1. HP Mini 110-3131dx Screen Replacement, Screen: step 2, image 1 of 3 HP Mini 110-3131dx Screen Replacement, Screen: step 2, image 2 of 3 HP Mini 110-3131dx Screen Replacement, Screen: step 2, image 3 of 3
    • Slightly tilt the screen downward.
    • The screen is attached by internal clips and adhesive, which means that some force will be necessary for this step.
    • Use the plastic opening tool to force the screen bezel from the screen.
    • Locate the eight silver 2.9mm screws attaching the screen to the lid.
    • Using a PH1 philips head screwdriver detach the screws.
aarondcollege
1,297 Reputation
10 Guides authored
USF Tampa, Team 2-4, Cagle Fall 2016 Member of USF Tampa, Team 2-4, Cagle Fall 2016
USFT-CAGLE-F16S2G4
5 Members
10 Guides authored
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 491
