HP Mini 1000 PRAM Battery Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. HP Mini 1000 PRAM Battery Replacement, PRAM Battery: step 1, image 1 of 1
      • If present, carefully peel back the piece of black film attached to the heat sink to reveal the PRAM battery and its cable.
      Ask FixBot
    2. HP Mini 1000 PRAM Battery Replacement: step 2, image 1 of 2 HP Mini 1000 PRAM Battery Replacement: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers to pull the PRAM battery connector out of its socket on the motherboard.
      • Pull the connector parallel to the face of the motherboard toward the fan side of the computer.
      • Use the flat end of a spudger to pry the PRAM battery off the adhesive securing it to the motherboard.
      • Remove the PRAM battery.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 16
All Time: 298
