Installing HP Mini 1000 Heat Sink
  1. Installing HP Mini 1000 Heat Sink, Battery: step 1, image 1 of 2 Installing HP Mini 1000 Heat Sink, Battery: step 1, image 2 of 2
    • With the case closed, place the Mini 1000 top-side down on a flat surface.
    • Push both of the battery release latches toward each other.
  2. Installing HP Mini 1000 Heat Sink: step 2, image 1 of 1
    • Lift the battery out of the Mini 1000 from the edge closest to the release latches.
  3. Installing HP Mini 1000 Heat Sink, Keyboard: step 3, image 1 of 1
    • Remove the following two screws:
    • One 6 mm Phillips screw
    • One 4 mm Phillips screw
  4. Installing HP Mini 1000 Heat Sink: step 4, image 1 of 3 Installing HP Mini 1000 Heat Sink: step 4, image 2 of 3 Installing HP Mini 1000 Heat Sink: step 4, image 3 of 3
    • To facilitate the removal of the keyboard, it is recommended to push the keyboard outwards with one hand through the opening (highlighted in the third picture) located on the backside of the Mini 1000.
    • While pushing through the opening with one hand, grasp the left upper edge with the other hand and slightly pull the keyboard towards you.
    • Once an opening has been established, grasp the keyboard and slowly lift it upwards along the upper perimeter of the top edge.
  5. Installing HP Mini 1000 Heat Sink: step 5, image 1 of 1
    • Lift the keyboard out of the upper case, minding the cable that is still connecting it to the motherboard.
  6. Installing HP Mini 1000 Heat Sink: step 6, image 1 of 1
    • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the keyboard cable ZIF socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the cable out of its socket and remove the keyboard.
  7. Installing HP Mini 1000 Heat Sink, Hard Drive: step 7, image 1 of 2 Installing HP Mini 1000 Heat Sink, Hard Drive: step 7, image 2 of 2
    • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the SIM card ribbon cable ZIF socket.
    • Pull the SIM card ribbon cable out of its socket and peel it off the top of the hard drive enclosure.
  8. Installing HP Mini 1000 Heat Sink: step 8, image 1 of 1
    • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the hard drive cable ZIF socket.
  9. Installing HP Mini 1000 Heat Sink: step 9, image 1 of 1
    • Remove the two 4.5 mm Phillips screws securing the hard drive to the lower case.
  10. Installing HP Mini 1000 Heat Sink: step 10, image 1 of 2 Installing HP Mini 1000 Heat Sink: step 10, image 2 of 2
    • Lift the hard drive up and out of the lower case, being careful not to damage its cable in the process.
  11. Installing HP Mini 1000 Heat Sink, Upper Case: step 11, image 1 of 1
    • Using the sharp tip of a spudger, pry and remove the four plastic screw covers from the underside of the HP Mini 1000.
    • There are three different variations of the covers:
    • The two bottom covers are short in height and are notched to prevent incorrect insertion
    • The upper right cover is taller in height and is notched.
    • The upper left cover is taller in height and is not notched.
  12. Installing HP Mini 1000 Heat Sink: step 12, image 1 of 1
    • Remove the four 7 mm Phillips screws that secure the upper case to the lower case.
  13. Installing HP Mini 1000 Heat Sink: step 13, image 1 of 1
    • Flip the computer over and open the display.
    • Remove the two 4.5 mm Phillips screws securing the upper case to the lower case.
  14. Installing HP Mini 1000 Heat Sink: step 14, image 1 of 2 Installing HP Mini 1000 Heat Sink: step 14, image 2 of 2
    • Wedge the flat end of a spudger in between the upper case and lower case near the bottom right corner of the display.
    • Carefully pry and rock the spudger upwards to create a small gap between the upper case and lower case.
    • Continue the previously described motion along the right edge of the upper case to release the clips securing the upper case to the lower case.
  15. Installing HP Mini 1000 Heat Sink: step 15, image 1 of 2 Installing HP Mini 1000 Heat Sink: step 15, image 2 of 2
    • Repeat the same procedure as mentioned in the previous step to release the clips along the left side of the upper case.
  16. Installing HP Mini 1000 Heat Sink: step 16, image 1 of 1
    • Grasp the upper case and carefully lift it slightly upwards, freeing it from any remaining clips.
    • The upper case is still attached via the TouchPad ribbon cable that is connected to the motherboard. Do not remove it completely just yet.
  17. Installing HP Mini 1000 Heat Sink: step 17, image 1 of 1
    • Lay the upper case on top of the upper portion of the motherboard.
    • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the TouchPad cable ZIF socket.
    • Pull the TouchPad ribbon cable out of its socket.
    • Remove the upper case from the HP Mini 1000.
  18. Installing HP Mini 1000 Heat Sink, SD Card: step 18, image 1 of 3 Installing HP Mini 1000 Heat Sink, SD Card: step 18, image 2 of 3 Installing HP Mini 1000 Heat Sink, SD Card: step 18, image 3 of 3
    • Push the SD card toward the inside of the computer to unlock it from the lower case.
    • Pull the SD card out of the lower case.
  19. Installing HP Mini 1000 Heat Sink, Wi-Fi Board: step 19, image 1 of 1
    • If present, peel the sticker up off the top of the Wi-Fi board to reveal the Wi-Fi antenna connectors.
  20. Installing HP Mini 1000 Heat Sink: step 20, image 1 of 3 Installing HP Mini 1000 Heat Sink: step 20, image 2 of 3 Installing HP Mini 1000 Heat Sink: step 20, image 3 of 3
    • Pry the Wi-Fi antenna connectors (2 total) up off the Wi-Fi board.
    • During reassembly, remember to correctly connect the antenna cables to their respective terminals. The green labeled antenna is connected to the "MAIN" terminal and the white labeled antenna is connected to the "AUX" terminal.
  21. Installing HP Mini 1000 Heat Sink: step 21, image 1 of 1
    • Remove the single 3 mm Phillips screw securing Wi-Fi board to the motherboard.
  22. Installing HP Mini 1000 Heat Sink: step 22, image 1 of 1
    • Upon removing the Phillips screw that secures the Wi-Fi board to the motherboard, the Wi-Fi board should pop up from its top side nearest the antenna sockets.
    • Grasp the Wi-Fi board and lift it straight away from its socket on the motherboard.
  23. Installing HP Mini 1000 Heat Sink, Heat Sink: step 23, image 1 of 1
    • Remove the two 2.5 mm Phillips screws securing the heat sink to the motherboard.
  24. Installing HP Mini 1000 Heat Sink: step 24, image 1 of 2 Installing HP Mini 1000 Heat Sink: step 24, image 2 of 2
    • Carefully lift the heat sink off the face of the motherboard and de-route the curved section from next to the fan.
    • Before reinstalling the heat sink, be sure to apply a new layer of thermal paste to the CPU. We have a thermal paste guide that makes it easy.
    • Only apply a new layer of thermal paste to the face of the CPU. The CPU is the large processor located closest to the fan.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 14
All Time: 2,514
