Introduction
Use this guide to replace the hard drive.
With the case closed, place the Mini 1000 top-side down on a flat surface.
Push both of the battery release latches toward each other.
While pushing through the opening with one hand, grasp the left upper edge with the other hand and slightly pull the keyboard towards you.
Once an opening has been established, grasp the keyboard and slowly lift it upwards along the upper perimeter of the top edge.
Lift the keyboard out of the upper case, minding the cable that is still connecting it to the motherboard.
Use your fingernail or the flat end of a spudger to flip up the retaining flap on the keyboard cable ZIF socket.
Pull the cable out of its socket and remove the keyboard.
Use your fingernail or the flat end of a spudger to flip up the retaining flap on the SIM card ribbon cable ZIF socket.
Pull the SIM card ribbon cable out of its socket and peel it off the top of the hard drive enclosure.
Use your fingernail or the flat end of a spudger to flip up the retaining flap on the hard drive cable ZIF socket.
Lift the hard drive up and out of the lower case, being careful not to damage its cable in the process.
Carefully peel up the two foam bumpers from the ends stuck to the bottom of the hard drive.
Lift up the center retaining tab on the hard drive enclosure and simultaneously push the hard drive out through the open end of the enclosure.
Pull the hard drive cable out of its socket.
Hard drive remains.
