HP HDX 16-1160US DVD Drive Replacement
  1. HP HDX 16-1160US DVD Drive Replacement, Battery: step 1, image 1 of 1
    • Turn the device over so that the bottom side is facing up and the battery is facing away from you.
  2. HP HDX 16-1160US DVD Drive Replacement: step 2, image 1 of 3 HP HDX 16-1160US DVD Drive Replacement: step 2, image 2 of 3 HP HDX 16-1160US DVD Drive Replacement: step 2, image 3 of 3
    • Locate the slider under the right side of the battery.
    • Using your thumb, slide it all the way to the left until the front of the battery lifts up.
  3. HP HDX 16-1160US DVD Drive Replacement: step 3, image 1 of 1
    • With your thumb still holding the slider to the left, use the opposite hand to lift the battery out, removing it from the computer.
  4. HP HDX 16-1160US DVD Drive Replacement, Keyboard: step 4, image 1 of 1
    • Remove the three 4mm screws using Phillips #1 screw driver.
    • Remove the four 6mm screws using Phillips #1 screw driver.
    • Remove the two 3mm screws using Phillips #1 screw driver.
  5. HP HDX 16-1160US DVD Drive Replacement: step 5, image 1 of 1
    • Using your fingers, pry off the speaker cover.
  6. HP HDX 16-1160US DVD Drive Replacement: step 6, image 1 of 3 HP HDX 16-1160US DVD Drive Replacement: step 6, image 2 of 3 HP HDX 16-1160US DVD Drive Replacement: step 6, image 3 of 3
    • Use the plastic opener to pry up the chrome keyboard cover from the lab top itself. Carefully work around the edges by prying each snap individually.
    • Remove the chrome keyboard cover.
    • Be careful not to pull the chrome cover completely off because there is a black strip connecting it to the laptop itself.
  7. HP HDX 16-1160US DVD Drive Replacement: step 7, image 1 of 3 HP HDX 16-1160US DVD Drive Replacement: step 7, image 2 of 3 HP HDX 16-1160US DVD Drive Replacement: step 7, image 3 of 3
    • Locate and remove the two 4mm screws with the Phillips #1 screw driver.
  8. HP HDX 16-1160US DVD Drive Replacement: step 8, image 1 of 2 HP HDX 16-1160US DVD Drive Replacement: step 8, image 2 of 2
    • Using your hands, pull the keyboard out.
    • Do not pull completely off because there is a grey strip connecting it to the laptop itself.
  9. HP HDX 16-1160US DVD Drive Replacement: step 9, image 1 of 2 HP HDX 16-1160US DVD Drive Replacement: step 9, image 2 of 2
    • Lift the black tab using the plastic opening tool.
    • Gently pull the grey strip out, horizontally way from you. This will release the keyboard from the computer.
  10. HP HDX 16-1160US DVD Drive Replacement, DVD Drive: step 10, image 1 of 1
    • Use the Phillips #1 Screw Driver to unscrew the 5mm screw.
  11. HP HDX 16-1160US DVD Drive Replacement: step 11, image 1 of 1
    • Flip over the device so that the bottom side is facing up.
    • Use the Phillips #1 Screw Driver to unscrew the 7mm screw near the center of the device.
  12. HP HDX 16-1160US DVD Drive Replacement: step 12, image 1 of 1
    • Push down and pull out the DVD on the left side of the device.
3 other people completed this guide.
Marshall Reid
527 Reputation
3 Guides authored
Cal Poly, Team 12-38, Maness Spring 2014 Member of Cal Poly, Team 12-38, Maness Spring 2014
CPSU-MANESS-S14S12G38
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 17
All Time: 1,457
