HP G71t-300 DVD Drive Replacement
  1. HP G71t-300 DVD Drive Replacement, DVD Drive: step 1, image 1 of 3 HP G71t-300 DVD Drive Replacement, DVD Drive: step 1, image 2 of 3 HP G71t-300 DVD Drive Replacement, DVD Drive: step 1, image 3 of 3
    • Ground yourself by either touching an unpainted metal surface or by using the Anti-Static wrist strap.
    • Turn off the computer and remove the charger from the charging port.
    • Turn the laptop over and slide the battery release catch to the right. The battery will pop up from its slot. Remove it using your fingers.
  2. HP G71t-300 DVD Drive Replacement: step 2, image 1 of 2 HP G71t-300 DVD Drive Replacement: step 2, image 2 of 2
    • Remove the 6mm screw above the laptop stickers using a Phillips #0 screwdriver.
  3. HP G71t-300 DVD Drive Replacement: step 3, image 1 of 2 HP G71t-300 DVD Drive Replacement: step 3, image 2 of 2
    • Gently pull the DVD drive out of the slot on the right side of the laptop using your fingers and a metal spudger.
Rohan Mathew
513 Reputation
5 Guides authored
UC Davis, Team 2-3, Oliver Fall 2016 Member of UC Davis, Team 2-3, Oliver Fall 2016
UCD-OLIVER-F16S2G3
5 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 134
