Introduction
Make sure you have a compatible DVD drive with the same dimensions.
Tool used on this step:Anti-Static Wrist Strap$7.95
Ground yourself by either touching an unpainted metal surface or by using the Anti-Static wrist strap.
Turn off the computer and remove the charger from the charging port.
Turn the laptop over and slide the battery release catch to the right. The battery will pop up from its slot. Remove it using your fingers.
Gently pull the DVD drive out of the slot on the right side of the laptop using your fingers and a metal spudger.
