HP G71t-300 Cooling Fan Replacement
  1. HP G71t-300 Cooling Fan Replacement, Keyboard: step 1, image 1 of 3 HP G71t-300 Cooling Fan Replacement, Keyboard: step 1, image 2 of 3 HP G71t-300 Cooling Fan Replacement, Keyboard: step 1, image 3 of 3
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Ground yourself by either touching an unpainted metal surface or by using the Anti-Static wrist strap.
    • Turn off the computer and remove the charger from the charging port.
    • Turn the laptop over and slide the battery release catch to the right. The battery will pop up from its slot. Remove it using your fingers.
  2. HP G71t-300 Cooling Fan Replacement: step 2, image 1 of 2 HP G71t-300 Cooling Fan Replacement: step 2, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the four screws from the indicated cover.
    • Gently lift and remove the cover.
  3. HP G71t-300 Cooling Fan Replacement: step 3, image 1 of 2 HP G71t-300 Cooling Fan Replacement: step 3, image 2 of 2
    • Remove the five 6mm screws with the Phillips #0 screwdriver.
  4. HP G71t-300 Cooling Fan Replacement: step 4, image 1 of 2 HP G71t-300 Cooling Fan Replacement: step 4, image 2 of 2
    • Pry the keyboard off with a spudger. Be careful not to apply too much pressure and damage any components.
  5. HP G71t-300 Cooling Fan Replacement: step 5, image 1 of 2 HP G71t-300 Cooling Fan Replacement: step 5, image 2 of 2
    • Disconnect the clip attaching the keyboard wiring to the motherboard. Lift and remove the keyboard.
  6. HP G71t-300 Cooling Fan Replacement, Cooling Fan: step 6, image 1 of 3 HP G71t-300 Cooling Fan Replacement, Cooling Fan: step 6, image 2 of 3 HP G71t-300 Cooling Fan Replacement, Cooling Fan: step 6, image 3 of 3
    • Use a Phillips #0 screwdriver to remove the 6mm screw from the top panel.
    • Gently lift and remove the panel. Use a metal spudger if the it seems set in place.
  7. HP G71t-300 Cooling Fan Replacement: step 7, image 1 of 2 HP G71t-300 Cooling Fan Replacement: step 7, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the 6mm screw for the Wi-Fi module cover.
    • Remove the cover.
  8. HP G71t-300 Cooling Fan Replacement: step 8, image 1 of 2 HP G71t-300 Cooling Fan Replacement: step 8, image 2 of 2
    • Remove all fourteen 6mm screws using a Phillips #0 screwdriver.
  9. HP G71t-300 Cooling Fan Replacement: step 9, image 1 of 2 HP G71t-300 Cooling Fan Replacement: step 9, image 2 of 2
    • Partially separate the two panels until connectors are visible.
    • Unclip the wires that attach the trackpad module to the motherboard.
  10. HP G71t-300 Cooling Fan Replacement: step 10, image 1 of 2 HP G71t-300 Cooling Fan Replacement: step 10, image 2 of 2
    • Remove the five highlighted screws using a Phillips #0 screwdriver.
  11. HP G71t-300 Cooling Fan Replacement: step 11, image 1 of 2 HP G71t-300 Cooling Fan Replacement: step 11, image 2 of 2
    • Disconnect the five cables by gently pulling them from their slots.
  12. HP G71t-300 Cooling Fan Replacement: step 12, image 1 of 2 HP G71t-300 Cooling Fan Replacement: step 12, image 2 of 2
    • Press a metal spudger between the VGA port and the plastic housing to pry up the motherboard.
    • Remove the motherboard and turn it so that the fan is facing upward.
  13. HP G71t-300 Cooling Fan Replacement: step 13, image 1 of 3 HP G71t-300 Cooling Fan Replacement: step 13, image 2 of 3 HP G71t-300 Cooling Fan Replacement: step 13, image 3 of 3
    • Use a Phillips #0 screwdriver to loosen the three screws attaching the heatsink to the motherboard.
    • Remove the heatsink and fan assembly by unclipping the fan from the motherboard.
Rohan Mathew
513 Reputation
5 Guides authored
UC Davis, Team 2-3, Oliver Fall 2016 Member of UC Davis, Team 2-3, Oliver Fall 2016
UCD-OLIVER-F16S2G3
5 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 17
All Time: 383
