HP G60T-600 CTO Keyboard Replacement
  1. HP G60T-600 CTO Keyboard Replacement, Battery: step 1, image 1 of 1
    • Failure to remove the battery before performing any replacement guide may result in electric shock.
    • Close your device, then turn it over.
  2. HP G60T-600 CTO Keyboard Replacement: step 2, image 1 of 2 HP G60T-600 CTO Keyboard Replacement: step 2, image 2 of 2
    • Place your index finger on the ridged tab.
  3. HP G60T-600 CTO Keyboard Replacement: step 3, image 1 of 1
    • Apply moderate pressure to the tab and slide it to the right.
    • While the tab is on the right, you should be able to gently slide your battery out of your device.
  4. HP G60T-600 CTO Keyboard Replacement, Keyboard: step 4, image 1 of 2 HP G60T-600 CTO Keyboard Replacement, Keyboard: step 4, image 2 of 2
    • Unscrew the following 5mm screws with a #0 Phillips screwdriver.
  5. HP G60T-600 CTO Keyboard Replacement: step 5, image 1 of 1
    • Turn your laptop over and open it up.
    • Grip your laptop firmly from both sides and use your thumbs to slide the keyboard towards the screen.
  6. HP G60T-600 CTO Keyboard Replacement: step 6, image 1 of 1
    • Pull up on the top of your keyboard with medium force. It should start to pop out.
    • A prying tool may facilitate this task.
    • Run your hands underneath the edges of the keyboard until it is free from the device.
    • Do not pull hard to take the keyboard out. There is a small connection that needs to be undone.
  7. HP G60T-600 CTO Keyboard Replacement: step 7, image 1 of 2 HP G60T-600 CTO Keyboard Replacement: step 7, image 2 of 2
    • Place your thumbs on the two small, white tabs.
    • Push these tabs forward to release the connection and free the keyboard from the device.
Dominic DeSantis
772 Reputation
6 Guides authored
UMass Dartmouth, Team 4-5, Catania Fall 2016 Member of UMass Dartmouth, Team 4-5, Catania Fall 2016
UMASSD-CATANIA-F16S4G5
3 Members
6 Guides authored
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 11
All Time: 162
