HP Envy x360 m6-aq105dx Hard Drive Replacement
  1. HP Envy x360 m6-aq105dx Hard Drive Replacement, Back Cover: step 1, image 1 of 1
    • Ground yourself by touching a metal object or surface. This prevents electrical damage to other components in the laptop.
    • Remove the two 7.8 mm screws using the Phillips #0 screwdriver.
    • Remove the six 5.2 mm screws using the Torx T5 screwdriver.
  2. HP Envy x360 m6-aq105dx Hard Drive Replacement: step 2, image 1 of 1
    • Light to moderate force is required to remove the back cover.
    • Insert the Jimmy in between the frame of the laptop and the removable back cover and remove the back cover from the device.
  3. HP Envy x360 m6-aq105dx Hard Drive Replacement, Hard Drive: step 3, image 1 of 1
    • Attach the grounding bracelet s clip to the frame of the laptop then put on the grounding bracelet.
    • Remove the two 4.6mm screws securing the hard drive in place using the Phillips #0 screwdriver.
  4. HP Envy x360 m6-aq105dx Hard Drive Replacement: step 4, image 1 of 1
    • Remove the cable plugged into the hard drive.
  5. HP Envy x360 m6-aq105dx Hard Drive Replacement: step 5, image 1 of 1
    • Plug the removed cable into the new hard drive.
  6. HP Envy x360 m6-aq105dx Hard Drive Replacement: step 6, image 1 of 1
    • Secure the new hard drive with the two 4.6mm Phillips 0 head screws removed earlier.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 550
