Introduction
This guide is for the replacement of the Wireless Module. You will need a small plastic opening tool and a standard Phillips Head 1 Screwdriver.
  1. Flip the laptop over to expose the underside.
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
    • Use the Phillips Head 1 Screwdriver to remove the six 4 mm screws.
    • Disconnect the battery port from the motherboard by gently lifting it on both sides with the plastic opening tool.
    • Lift up the port with the tool.
    • Lift the battery out of the laptop with your hands.
    • Remove the two antenna cables connected to the wireless module by wedging the small plastic opening tool between the cables and the wireless module and lifting up.
    • Remove the 3.5 mm Phillips Head screw with the Phillip Head 1 screwdriver.
    • Slide the wireless module towards the back of the computer to remove it.
Joey Chen
243 Reputation
2 Guides authored
Cal Poly, Team S4-G3, Livingston Fall 2017 Member of Cal Poly, Team S4-G3, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G3
4 Members
9 Guides authored
One Comment
That thing is not a graphic card. It’s a dual band wireless module/chip.
Pritam Mandal - Reply
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 393
