HP Envy x360 m6-aq005dx Battery Replacement
  1. HP Envy x360 m6-aq005dx Battery Replacement, Back Panel: step 1, image 1 of 2 HP Envy x360 m6-aq005dx Battery Replacement, Back Panel: step 1, image 2 of 2
    • Use the plastic opening tool to remove the gray rubber pads on the bottom of the laptop. For our device we only needed to remove the two at the top.
  2. HP Envy x360 m6-aq005dx Battery Replacement: step 2, image 1 of 3 HP Envy x360 m6-aq005dx Battery Replacement: step 2, image 2 of 3 HP Envy x360 m6-aq005dx Battery Replacement: step 2, image 3 of 3
    • Use a Torx T5 screwdriver to remove the six 5.1 mm screws.
    • Use a JIS #1 screwdriver to remove the two 7.2mm screws.
  3. HP Envy x360 m6-aq005dx Battery Replacement: step 3, image 1 of 1
    • Use a plastic opening tool to pry open the case. Go slowly around the edge. You will hear popping noises, such are due to popping open the small joints that keep the cover attached.
  4. HP Envy x360 m6-aq005dx Battery Replacement, Battery: step 4, image 1 of 2 HP Envy x360 m6-aq005dx Battery Replacement, Battery: step 4, image 2 of 2
    • Use a J1 to remove the six 4.7 mm screws.
  5. HP Envy x360 m6-aq005dx Battery Replacement: step 5, image 1 of 1
    • Battery might cause a small electric shock.
    • Use tweezers to disconnect the battery from the motherboard.
Matthew Martin
711 Reputation
5 Guides authored
USF Tampa, Team S13-G17, Cagle Fall 2017 Member of USF Tampa, Team S13-G17, Cagle Fall 2017
USFT-CAGLE-F17S13G17
4 Members
7 Guides authored
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 55
All Time: 15,633
