HP Envy x360 15-bp143cl SSD Replacement
  1. HP Envy x360 15-bp143cl SSD Replacement, Battery: step 1, image 1 of 1
    • Flip the laptop over.
    • Peel off the rubber strip closest to the hinges.
  2. HP Envy x360 15-bp143cl SSD Replacement: step 2, image 1 of 1
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the four 6.5mm screws that were underneath the rubber strip.
  3. HP Envy x360 15-bp143cl SSD Replacement: step 3, image 1 of 1
    • Use a Torx T5 screwdriver (T5 bit) to remove the three 5mm screws near the bottom edge of the laptop.
  4. HP Envy x360 15-bp143cl SSD Replacement: step 4, image 1 of 1
    • Lift the back panel to remove it from the laptop.
    • Use an opening tool to pry open the back panel if it does not easily lift apart.
  5. HP Envy x360 15-bp143cl SSD Replacement: step 5, image 1 of 2 HP Envy x360 15-bp143cl SSD Replacement: step 5, image 2 of 2
    • Use a Phillips #1 screwdriver (PH1) to remove the seven 4mm screws indicated by the gray arrows on the battery.
  6. HP Envy x360 15-bp143cl SSD Replacement: step 6, image 1 of 1
    • Pull the battery from the connecting port and lift to remove it from the laptop.
  7. HP Envy x360 15-bp143cl SSD Replacement, SSD: step 7, image 1 of 1
    • Use a Phillips #1 screwdriver to remove the single 4 mm screw securing the SSD.
  8. HP Envy x360 15-bp143cl SSD Replacement: step 8, image 1 of 1
    • Pull the SSD directly out its port.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 17
Past 30 Days: 72
All Time: 5,182
