Introduction
In this repair guide, you will be learning how to replace the WLAN (Wi-Fi) card on your HP Envy m6-1105dx. For this repair, you will need a JIS #0 screwdriver. You will have to loosen a screw to be able to remove the main service panel on the case of your HP Envy m6-1105dx. Once this is removed, you can access the screw holding the cover for the WLAN card in place, and remove both parts. You will then have to gently (using a plastic tool) pry up the antenna connected to the WLAN card. This will allow you to reach the screws holding the WLAN card in place. Then, gently pull out the WLAN card.
Turn the computer completely off.
Disconnect any devices you have on it.
Turn the computer upside down on a flat surface.
Release the screw in the center of the service cover.
Slide the battery release latch and pull cover towards you.
Lift cover off.
