HP Envy TouchSmart 4-1215dx SSD Replacement
  1. HP Envy TouchSmart 4-1215dx SSD Replacement, Back Panel Assembly: step 1, image 1 of 2 HP Envy TouchSmart 4-1215dx SSD Replacement, Back Panel Assembly: step 1, image 2 of 2
    • Remove the thirteen Phillips #0 screws.
  2. HP Envy TouchSmart 4-1215dx SSD Replacement: step 2, image 1 of 2 HP Envy TouchSmart 4-1215dx SSD Replacement: step 2, image 2 of 2
    • Pull the panel up and off to remove from the laptop.
  3. HP Envy TouchSmart 4-1215dx SSD Replacement, Battery: step 3, image 1 of 2 HP Envy TouchSmart 4-1215dx SSD Replacement, Battery: step 3, image 2 of 2
    • Unplug the battery from the motherboard.
  4. HP Envy TouchSmart 4-1215dx SSD Replacement: step 4, image 1 of 2 HP Envy TouchSmart 4-1215dx SSD Replacement: step 4, image 2 of 2
    • Remove the three Phillips #0 screws from the battery.
    • Pull the battery out of the laptop.
  5. HP Envy TouchSmart 4-1215dx SSD Replacement, SSD: step 5, image 1 of 2 HP Envy TouchSmart 4-1215dx SSD Replacement, SSD: step 5, image 2 of 2
    • Remove the single 2 mm screw from the SSD using a Phillips #0 screwdriver.
    • The SSD will pop up when the screw is removed.
  6. HP Envy TouchSmart 4-1215dx SSD Replacement: step 6, image 1 of 2 HP Envy TouchSmart 4-1215dx SSD Replacement: step 6, image 2 of 2
    • Gently pull the SSD card from its slot at a 45 degree angle until the card is released.
Emilie Rossmiller
85 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 10
All Time: 350
