Introduction
This device guide aims to replace a non-functioning HP Envy Sleekbook m6-k0101x keyboard. This guide should only be used if none of these troubleshooting ideas provide any desirable results. Before dismantling your device, ensure that your workspace is free from any open liquids or spare objects that might hinder this process.
Flip up the black tab on the ZIF connector and pull the blue and white flex cable connecting the touchpad to the motherboard.
In order to remove the RAM, pull each silver clip (one at a time) away from the RAM.
The RAM chip should pop up. Gently remove the RAM from the motherboard.
Remove four 3mm Phillips #00 screws from the heatsink.
Lift the heat sink out from the device and set it aside.
Remove the two 3mm Phillips #00 screws that secure the speaker to the device.
Remove the four 4mm Phillips #00 screws from the bracket.
Locate the speaker cable connecting the speaker to the audio board. Gently tug on this cable to dislodge. Set the speaker aside.
Remove the two 3mm Phillips #00 screws that secure the RJ-45 module.
Lift the white tab on the ZIF connector and pull the ribbon cable out.
Remove the 3mm Phillips #00 screw connecting the chip to the housing.
Lift up silver bracket.
Lift up the white flap on the ZIF connector and remove the purple ribbon cable.
Remove the 4mm Phillips #00 screws.
Remove the silver 3mm Phillips 3 mm screw.
Lift all three black flaps in the ZIF connectors and remove the attached ribbon cables.
Use your hand and gently remove the connector to the back up battery for the motherboard.
Remove the 4 Phillips 4 mm screws securing the motherboard to the device using the Phillips screwdriver.
Lift the board at an angle and pull outwards to dislodge it from the device.
Remove the 13 Silver Phillips 3 mm screws that secure the keyboard bracket to the computer.
Lift up the keyboard from the bracket and pull outwards to remove the keyboard from the device.
