HP Envy 7640 Paper Roller Replacement
  1. HP Envy 7640 Paper Roller Replacement, Paper Roller: step 1, image 1 of 3 HP Envy 7640 Paper Roller Replacement, Paper Roller: step 1, image 2 of 3 HP Envy 7640 Paper Roller Replacement, Paper Roller: step 1, image 3 of 3
    • Open the printer by pushing upwards on the plastic tabs located on the sides of the printer.
    • Remove the opening assist from its purchase by pushing it toward the front of the printer with a nylon spudger.
    • Remove the spring-loaded clip attached to the top of the printer by pushing it off of the hook.
  2. HP Envy 7640 Paper Roller Replacement: step 2, image 1 of 2 HP Envy 7640 Paper Roller Replacement: step 2, image 2 of 2
    • Remove the last ten 12mm screws by placing the Torx 9 screwdriver in the screw slot and turning counterclockwise.
    • Remove the last two 12mm screws by placing the Torx 9 screwdriver in the screw slot and turning counterclockwise; the screen plate can now be separated from the printer by pushing out and to the right.
    • Take out the inner plastic frame (this piece is removeable after having removed the ten 12 mm screws outlined in the first bullet) by grasping the frame with both hands and carefully pulling the frame away from the printer body.
  3. HP Envy 7640 Paper Roller Replacement: step 3, image 1 of 2 HP Envy 7640 Paper Roller Replacement: step 3, image 2 of 2
    • Grasp the gray lever of the black plastic cover of the rollers and gently pull the lever up and to the right.
  4. HP Envy 7640 Paper Roller Replacement: step 4, image 1 of 3 HP Envy 7640 Paper Roller Replacement: step 4, image 2 of 3 HP Envy 7640 Paper Roller Replacement: step 4, image 3 of 3
    • Press the lever outwards and away from the paper rollers with one hand.
    • Pull the paper rollers up and out of your HP printer with one hand while the other continues to depress the lever away from the paper rollers.
3 other people completed this guide.
Nicholas Sheffler
393 Reputation
3 Guides authored
Cal Poly, Team S1-G2, Livingston Winter 2018 Member of Cal Poly, Team S1-G2, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G2
3 Members
10 Guides authored
2 Comments
is there a video
Joshua Williams - Reply
Thank you, steps provided easy to follow.
Robyn McDaries - Reply
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 79
All Time: 5,802
