HP Envy 23-d060qd TouchSmart Hard Drive Replacement
  1. HP Envy 23-d060qd TouchSmart Hard Drive Replacement, Back Panel: step 1, image 1 of 1
    • Use your hands to unclip the plastic snaps on the back panel of the device.
  2. HP Envy 23-d060qd TouchSmart Hard Drive Replacement: step 2, image 1 of 1
    • Remove the three 11.5mm PH2 screws from the back panel.
    • The screws will not fall out of the back panel, but they will unscrew to release the back panel.
  3. HP Envy 23-d060qd TouchSmart Hard Drive Replacement: step 3, image 1 of 1
    • Now, take the back panel off by pulling at it gently with your hands.
  4. HP Envy 23-d060qd TouchSmart Hard Drive Replacement, Hard Drive: step 4, image 1 of 1
    • Remove the one 13.5mm PH2 screw.
  5. HP Envy 23-d060qd TouchSmart Hard Drive Replacement: step 5, image 1 of 1
    • Unsnap the wire mechanism to release the hard drive.
  6. HP Envy 23-d060qd TouchSmart Hard Drive Replacement: step 6, image 1 of 2 HP Envy 23-d060qd TouchSmart Hard Drive Replacement: step 6, image 2 of 2
    • Detach the hard drive assembly by pulling it out of the socket.
  7. HP Envy 23-d060qd TouchSmart Hard Drive Replacement: step 7, image 1 of 1
    • Remove the two 8.5mm PH2 screws on each side of the hard drive cover.
  8. HP Envy 23-d060qd TouchSmart Hard Drive Replacement: step 8, image 1 of 1
    • Detach the hard drive cover by sliding it off from the rest of the hard drive
    • Replace the old hard drive with your new hard drive.
5 other people completed this guide.
Zachary Dicks
1,117 Reputation
7 Guides authored
Cal Poly, Team 5-10, Maness Fall 2015 Member of Cal Poly, Team 5-10, Maness Fall 2015
CPSU-MANESS-F15S5G10
4 Members
14 Guides authored
One Comment
Thank you so much my hard drive is bad this is going to be a quick fix and save me money you made this for dummies I LOVE IT can u tell me when I replace the hard drive will I lose everything on my computer already such as photos,files, I have everything in office purchased on the computer ? If so is there a way not to lose anything
jessica Kramer - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 30
All Time: 6,831
