HP Envy 17-J013CL Battery Replacement
  1. HP Envy 17-J013CL Battery Replacement, Battery: step 1, image 1 of 1
    • Lay the laptop with the battery facing towards you.
    • Remember to disconnect the AC cable and other power sources from the device before replacing/repairing parts.
  2. HP Envy 17-J013CL Battery Replacement: step 2, image 1 of 1
    • Grab hold of the small battery slider and apply pressure to the right.
    • The laptop itself will push the battery out for you once the switch slides all the way to the right.
  3. HP Envy 17-J013CL Battery Replacement: step 3, image 1 of 3 HP Envy 17-J013CL Battery Replacement: step 3, image 2 of 3 HP Envy 17-J013CL Battery Replacement: step 3, image 3 of 3
    • Pull the battery out and let go of the battery slider.
To reassemble your device, line up the battery and place it down into the metallic prongs for a stable connection.
2 other people completed this guide.
Matt McBride
845 Reputation
6 Guides authored
USF Tampa, Team 16-6, Blackwell Spring 2017 Member of USF Tampa, Team 16-6, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G6
3 Members
6 Guides authored
One Comment
where does one buy a replacement battery for this HP envy17?
brandondelcastillo - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 13
All Time: 1,962
