HP Elitebook 8570w Keyboard Replacement
    1. HP Elitebook 8570w Keyboard Replacement, Keyboard: step 1, image 1 of 1
      • Begin by removing the back cover of the computer.
      • Push the marked slider to the right.
      • While pushing the slider, pull the cover towards yourself to remove.
      Ask FixBot
    2. HP Elitebook 8570w Keyboard Replacement: step 2, image 1 of 1
      • Locate the 3 screws marked in the photo.
      • Using a Phillips screwdriver, unscrew all 3 0.8mm screws completely and place to the side.
      Ask FixBot
    3. HP Elitebook 8570w Keyboard Replacement: step 3, image 1 of 2 HP Elitebook 8570w Keyboard Replacement: step 3, image 2 of 2
      • Flip the computer so it is laying on its side.
      • Using your fingers or a tool, begin to wedge back/pull off the top of the keyboard panel.
      • Once freeing the keyboard panel from the computer, it should look like photo #2.
      Ask FixBot
    4. HP Elitebook 8570w Keyboard Replacement: step 4, image 1 of 1
      • Locate all 3 places of attachment marked in the photo.
      • Each de-attachment is explained in the following steps.
      Ask FixBot
    5. HP Elitebook 8570w Keyboard Replacement: step 5, image 1 of 2 HP Elitebook 8570w Keyboard Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Locate the white rectangle base beneath the blue and white strip attached to the computer and keyboard.
      • Using a wedging tool, pull the white base up slightly to loosen the grip on the blue and white strip.
      • With the white base slightly risen, use tweezers to carefully pull out/remove the strip from the computer.
      Ask FixBot
    6. HP Elitebook 8570w Keyboard Replacement: step 6, image 1 of 2 HP Elitebook 8570w Keyboard Replacement: step 6, image 2 of 2
      • Locate the white rectangle base beneath the burn orange strip attached to the computer and the keyboard.
      • Like the previous step, use a plastic or nylon tool to slightly raise the white base to loosen the grip on the ribbon cable.
      • Using tweezers or your fingers, carefully pull up on the ribbon cable to completely detach it from the computer.
      Ask FixBot
    7. HP Elitebook 8570w Keyboard Replacement: step 7, image 1 of 1
      • Locate the black rectangle base at the bottom of the thick ribbon cable.
      • Like previous steps, use a tool to wedge the base upward to slightly lift it in order to loosen the grip on the silver ribbon cable.
      • While the base is lifted, use your fingers to carefully pull out the silver ribbon cable thus freeing it from the computer.
      Ask FixBot
3 other people completed this guide.
Marko Tardio
226 Reputation
1 Guide authored
Baylor, Team S8-G5, Johnson Fall 2017 Member of Baylor, Team S8-G5, Johnson Fall 2017
BU-JOHNSON-F17S8G5
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 65
All Time: 8,741
