Introduction
Replacing the RAM in your HP EliteBook 840 G1.
Slide the latch, to the right, away from the lock symbol.
Slide the cover away from the latch to remove it.
Once the cover is removed you will be able to see the battery and the two latches that hold it in place.
The two latches should be pulled back, one of which is spring loaded and must be held in place in order to remove the battery.
