Introduction
If your PC is overheating, you may simply have to dust and get rid of lint off the devices fan and heatsink or replacing the fan and heatsink on your HP EliteBook 840 G1
Slide the latch, to the right, away from the lock symbol.
Slide the cover away from the latch to remove it.
Once the cover is removed you will be able to see the battery and the two latches that hold it in place.
The two latches should be pulled back, one of which is spring loaded and must be held in place in order to remove the battery.
Tool used on this step:Anti-Static Wrist Strap$7.95
Identify the RAM and the pull tabs that will be used in the next step.
Grab the pull tab on the hard drives plastic casing and pull it out and to the side.
Remove the 2.5" hard drive from the plastic bracket.
In order to take out the fan and heatsink the plastic cover must first be taken off.
Remove the eight 2 mm Phillips #1 screws.
Remove the thirteen 6 mm Torx T8 screws.
Remove the single 7 mm Phillips #1 screw.
Loosen the two Phillips #1 screws. These screws will remain captive to the device.
Using the plastic opening tools, remove the plastic cover by beginning at one of the corners and prying it up.
Use the plastic opening tools to remove the keyboard, starting at one of the top corners.
Once the keyboard is removed, detach the ribbons connecting the keyboard to the laptop by prying the small tab and sliding the ribbon out.
Use the plastic opening tools to remove the tape covering the wires connected from the fan to the motherboard.
Disconnect the fan by sliding the wire out.
Remove the fan by lifting it up and sliding it out.
Remove the heat sink by lifting it up and sliding it out.
