HP Elitebook 820 G1 RAM Replacement
  1. HP Elitebook 820 G1 RAM Replacement, Battery: step 1, image 1 of 1
    • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Turn over laptop so that the bottom is showing.
    • Unlock the latch.
  2. HP Elitebook 820 G1 RAM Replacement: step 2, image 1 of 1
    • Remove the back cover and you will then be able to see the battery.
  3. HP Elitebook 820 G1 RAM Replacement: step 3, image 1 of 1
    • Unlatch the two latches securing the battery in the case.
  4. HP Elitebook 820 G1 RAM Replacement: step 4, image 1 of 1
    • Use a plastic opening tool to lift and remove the battery.
  5. HP Elitebook 820 G1 RAM Replacement, RAM: step 5, image 1 of 1
    • Once the battery is removed from the device, slide both latches away from the RAM module with your fingers.
    • The latches are spring assisted and the RAM module will lift for removal.
Ashley Francavilla
103 Reputation
1 Guide authored
USF Tampa, Team S5-G1, Eyestone Spring 2018 Member of USF Tampa, Team S5-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S5G1
3 Members
7 Guides authored
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 8
All Time: 1,147
