HP Elitebook 820 G1 Keyboard Replacement
  1. HP Elitebook 820 G1 Keyboard Replacement, Battery: step 1, image 1 of 1
    • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Turn over laptop so that the bottom is showing.
    • Unlock the latch.
  2. HP Elitebook 820 G1 Keyboard Replacement: step 2, image 1 of 1
    • Remove the back cover and you will then be able to see the battery.
  3. HP Elitebook 820 G1 Keyboard Replacement: step 3, image 1 of 1
    • Unlatch the two latches securing the battery in the case.
  4. HP Elitebook 820 G1 Keyboard Replacement: step 4, image 1 of 1
    • Use a plastic opening tool to lift and remove the battery.
  5. HP Elitebook 820 G1 Keyboard Replacement, Keyboard: step 5, image 1 of 1
    • Remove the two Phillips #0 screws securing the keyboard to the laptop.
    • Turn the laptop over and lift the display to reveal the keyboard.
  6. HP Elitebook 820 G1 Keyboard Replacement: step 6, image 1 of 1
    • Insert the plastic spudger between the keyboard and the housing.
    • Start at the corner.
  7. HP Elitebook 820 G1 Keyboard Replacement: step 7, image 1 of 3 HP Elitebook 820 G1 Keyboard Replacement: step 7, image 2 of 3 HP Elitebook 820 G1 Keyboard Replacement: step 7, image 3 of 3
    • 4 tabs are located at the top of the keyboard, which lock it in place.
    • Pry and twist the spudger along the top of the keyboard until each tab is released.
  8. HP Elitebook 820 G1 Keyboard Replacement: step 8, image 1 of 1
    • Pull back the keyboard from the top.
    • Be mindful of the fragile cables behind it.
  9. HP Elitebook 820 G1 Keyboard Replacement: step 9, image 1 of 3 HP Elitebook 820 G1 Keyboard Replacement: step 9, image 2 of 3 HP Elitebook 820 G1 Keyboard Replacement: step 9, image 3 of 3
    • Flip up the connecting flap on each of the three ribbon cables.
  10. HP Elitebook 820 G1 Keyboard Replacement: step 10, image 1 of 3 HP Elitebook 820 G1 Keyboard Replacement: step 10, image 2 of 3 HP Elitebook 820 G1 Keyboard Replacement: step 10, image 3 of 3
    • Remove each of the three cables by gently pulling them from their respective connectors.
  11. HP Elitebook 820 G1 Keyboard Replacement: step 11, image 1 of 1
    • Remove the keyboard from the housing.
Lauren Vance
388 Reputation
2 Guides authored
IUPUI, Team S1-G2, Harley Fall 2018 Member of IUPUI, Team S1-G2, Harley Fall 2018
IUPUI-HARLEY-F18S1G2
2 Members
4 Guides authored
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 62
All Time: 11,098
