HP EliteBook 1050 G1 RAM Replacement
  1. HP EliteBook 1050 G1 RAM Replacement, RAM: step 1, image 1 of 2 HP EliteBook 1050 G1 RAM Replacement, RAM: step 1, image 2 of 2
    • Remove the five 8.7mm screws with a Torx T8 driver.
    • Remove the two 5.5mm screws with a Torx T8 driver.
    • Remove the two 6.6mm screws with a Torx T8 driver.
    • Lift open the back panel with a Jimmy.
  2. HP EliteBook 1050 G1 RAM Replacement: step 2, image 1 of 3 HP EliteBook 1050 G1 RAM Replacement: step 2, image 2 of 3 HP EliteBook 1050 G1 RAM Replacement: step 2, image 3 of 3
    • Pull the clips on either side of the RAM chip away from each other using your fingers.
    • As you pry apart the clips, the RAM should pop up to rest at an angle to the motherboard.
    • Slide the RAM chips out of their respective slots.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 466
