HP Chromebook x360 14c-ca0053 Screen Replacement
  1. HP Chromebook x360 14c-ca0053 Screen Replacement, Lower Case: step 1, image 1 of 2 HP Chromebook x360 14c-ca0053 Screen Replacement, Lower Case: step 1, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to apply light pressure on the outer sides of the 2 small screw covers located near the bottom of the device.
    • Rotate the covers until they pop up out of the screw socket enough to remove them with tweezers.
  2. HP Chromebook x360 14c-ca0053 Screen Replacement: step 2, image 1 of 2 HP Chromebook x360 14c-ca0053 Screen Replacement: step 2, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the two 3.5 mm screws.
  3. HP Chromebook x360 14c-ca0053 Screen Replacement: step 3, image 1 of 3 HP Chromebook x360 14c-ca0053 Screen Replacement: step 3, image 2 of 3 HP Chromebook x360 14c-ca0053 Screen Replacement: step 3, image 3 of 3
    • Use tweezers to peel back the feet on the top and bottom of the Chromebook to reveal four additional screws.
  4. HP Chromebook x360 14c-ca0053 Screen Replacement: step 4, image 1 of 2 HP Chromebook x360 14c-ca0053 Screen Replacement: step 4, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the 4 7 mm screws located at each corner of the device under the grips.
  5. HP Chromebook x360 14c-ca0053 Screen Replacement: step 5, image 1 of 3 HP Chromebook x360 14c-ca0053 Screen Replacement: step 5, image 2 of 3 HP Chromebook x360 14c-ca0053 Screen Replacement: step 5, image 3 of 3
    • Insert an opening pick between lower case and chassis.
    • Separate the lower case from the frame by sliding the opening pick along the perimeter until the case releases.
  6. HP Chromebook x360 14c-ca0053 Screen Replacement: step 6, image 1 of 1
    • Lift the lower case up and off.
  7. HP Chromebook x360 14c-ca0053 Screen Replacement, Battery: step 7, image 1 of 3 HP Chromebook x360 14c-ca0053 Screen Replacement, Battery: step 7, image 2 of 3 HP Chromebook x360 14c-ca0053 Screen Replacement, Battery: step 7, image 3 of 3
    Buy
    • Open the tweezers wide enough to fit on each side of motherboard battery connection.
    • Pull the connector directly out of its socket.
  8. HP Chromebook x360 14c-ca0053 Screen Replacement: step 8, image 1 of 2 HP Chromebook x360 14c-ca0053 Screen Replacement: step 8, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the five 3 mm screws that secure the battery.
    • These screws are labeled 1-5.
  9. HP Chromebook x360 14c-ca0053 Screen Replacement: step 9, image 1 of 1
    • Lift the battery up and out.
    • Be careful as to not puncture or damage the battery.
  10. HP Chromebook x360 14c-ca0053 Screen Replacement, Screen: step 10, image 1 of 2 HP Chromebook x360 14c-ca0053 Screen Replacement, Screen: step 10, image 2 of 2
    • There are six tabs at the top side the screen. Use the opening pick to create a small gap between the back panel of the screen and the display screen releasing those six tabs.
    • If it is difficult to insert the opening pick between the screen and back panel, use the metal spudger instead.
  11. HP Chromebook x360 14c-ca0053 Screen Replacement: step 11, image 1 of 2 HP Chromebook x360 14c-ca0053 Screen Replacement: step 11, image 2 of 2
    Buy
    • Use tweezers to locate the black tape between the back panel and the display screen.
    • Pull the adhesive through the gap on each side of the screen until it comes loose.
    • Replace the adhesive during reassembly.
    • If pulling the black adhesive fails, use a hair dryer to soften the adhesive while exerting constant pressure between the back panel and the display screen.
  12. HP Chromebook x360 14c-ca0053 Screen Replacement: step 12, image 1 of 2 HP Chromebook x360 14c-ca0053 Screen Replacement: step 12, image 2 of 2
    • Use tweezers to peel back the square-shaped silver tape on the top side of the device.
  13. HP Chromebook x360 14c-ca0053 Screen Replacement: step 13, image 1 of 2 HP Chromebook x360 14c-ca0053 Screen Replacement: step 13, image 2 of 2
    • Use tweezers to lift up the black metal wire covering the connector.
    • Gently pull the display connector out from the device.
  14. HP Chromebook x360 14c-ca0053 Screen Replacement: step 14, image 1 of 2 HP Chromebook x360 14c-ca0053 Screen Replacement: step 14, image 2 of 2
    • Peel the black tape that holds the black wire to the screen then use tweezers to gently pull the connector from the socket.
  15. HP Chromebook x360 14c-ca0053 Screen Replacement: step 15, image 1 of 2 HP Chromebook x360 14c-ca0053 Screen Replacement: step 15, image 2 of 2
    • Remove the screen.
Cassidy
691 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 68
All Time: 973
