HP Chromebook 14-q029wm Screen Replacement
  1. HP Chromebook 14-q029wm Screen  Replacement, Screen: step 1, image 1 of 3 HP Chromebook 14-q029wm Screen  Replacement, Screen: step 1, image 2 of 3 HP Chromebook 14-q029wm Screen  Replacement, Screen: step 1, image 3 of 3
    • Remove these two sticker covers which cover two screws.
    • Remove the two 2mm Phillips #0 screws.
  2. HP Chromebook 14-q029wm Screen  Replacement: step 2, image 1 of 3 HP Chromebook 14-q029wm Screen  Replacement: step 2, image 2 of 3 HP Chromebook 14-q029wm Screen  Replacement: step 2, image 3 of 3
    • Unsnap the plastic edge around the screen using an opening tool.
    • You will have to close the screen partially to unsnap the plastic near the hinge.
    • Be careful not to break the plastic.
  3. HP Chromebook 14-q029wm Screen  Replacement: step 3, image 1 of 1
    • Remove the four 3mm Phillips #0 screws.
    • Be careful not to drop the screen after you remove the last screw.
  4. HP Chromebook 14-q029wm Screen  Replacement: step 4, image 1 of 3 HP Chromebook 14-q029wm Screen  Replacement: step 4, image 2 of 3 HP Chromebook 14-q029wm Screen  Replacement: step 4, image 3 of 3
    • Unplug the wire attached at the bottom of the screen.
    • To unplug the wire, peel back the sticker and gently pull the sticker holding close to the wire to unplug.
Andrew Pratt
669 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 508
